$10.8 billion
That’s how much Steve Jobs left behind, and his kids didn’t inherit. The Apple founder’s estate went almost entirely to his wife, Laurene, who made it clear: The dynasty dies with her. So while Eve Jobs models, Reed invests in cancer research, and Lisa Brennan-Jobs writes about her dad’s icy legacy, none of them are cashing in.
⚡️ 3-second tech genius: Use voice typing in Google Docs: Tools > Voice typing.
🔐 Make your password tougher: The longer it is, the more difficult it is to crack. Try to aim for at least 16 characters. Mix in uppercase, lowercase, numbers and symbols. I use passphrases, like mashing up a few random words. For example: iL0veKimK0m@ndoSoMuch!. Easy to remember, hard for hackers to guess. Or use the password manager I do.
🛡️ I don’t go online without ExpressVPN: Neither should you. It hides your IP, encrypts your data and keeps snoops out. Fast, private, secure. Get four extra months free with this limited time offer.
AirPods keep falling out? You’re not imagining it. Series 3 and 4 have a chunkier shape that doesn’t sit as well, especially if you’re moving around. Try this: Pop it in, then twist it a bit so the stem points toward your mouth. Now it won’t fly out mid-jog.
Speed up your Android: If your phone feels sluggish, your home screen might be the problem. Too many widgets, like weather or news feeds, can put extra stress on the system each time you wake it up. Ditch the ones you don’t need: Long-press a widget and tap Remove.
Uber senior accounts: Larger text, fewer buttons and clearer instructions. Perks include saved destinations and pay with a Medicare flex card. FYI: It’s part of Uber’s family profile, but anyone can try this by turning on Simple Mode in the app’s Account section.
📅 Search by date range in Gmail: Need to find emails from a specific time frame? In the search bar, type: after:2025/01/01 before:2025/03/01. This shows emails from Jan. 2 to Feb. 28, 2025. You can narrow it more like from:kim@example.com or has:attachment. Neat.
⚡️ 3-second tech genius: Open a private browser window fast: Ctrl + Shift + N (Windows) or Command + Shift + N (Mac).
