Stop deleting photos manually: An AI cleanup guide
If your phone is one bad selfie away from digital combustion, you need this hilarious, smart how-to on cutting the photo clutter.
Stop deleting photos manually: An AI cleanup guide Gemini
Hear that sound? It’s your phone gasping for air, “Help me, help me, Obi-Wan Komando!”
The 4,000 identical, blurry photos of the same sunset and the accidental videos of your pocket are stifling. Now that holiday hustle is over, let’s get to work.
🔍 Visual search purge
You don’t need to scroll to find the junk. Use the AI’s brain to hunt it down by category.
  • Step 1: Open your Photos app and tap the Search icon.
  • Step 2: Instead of a name, type Receipts, Documents or even Blurry. The AI identifies the content of the images.
  • Step 3: Hit Select, then Select All and the Trash Can to wipe them all out.
💣 Duplicates nuke
You only need one photo of every shot, not three.
  • On iPhone: Go to Photos > Collections, scroll to the bottom to Duplicates, and tap Merge. It intelligently keeps the highest-resolution version and kills the space-wasting clones.
  • On Android: Open Files by Google > Clean. It will instantly show you a Delete Duplicates card. One tap, and the clutter is gone.
🕵️ AI auditor secret
Stop guessing which photo is the best one. Let the world’s most powerful AI be your private photo editor. Start by opening the album or folder with your holiday and Christmas photos.
  • Step 1: Upload them to ChatGPT or Gemini, and use this prompt: “I’m attaching 50 photos. Identify which ones are blurry, have someone’s eyes closed or are nearly identical. List the file names I should delete to keep only the ‘Hero’ shots.“
  • Step 2: The AI looks at the visual composition and lighting in seconds. It’s like hiring a professional photographer to curate your life for free.
🎬 The gigabyte killer
If you want the most storage back in the least amount of time, go for the big fish.
  • On iPhone: Go to Settings > General > iPhone Storage. Scroll down to Review Large Attachments. This shows you every giant video or file hiding in your messages that you forgot to delete.
  • On Android: Open the Google Photos app, tap your profile icon, then Free up space. It will specifically highlight “Large photos & videos” that are safe to toss.
Don’t keep this tech savviness to yourself! If this guide helped you develop a better frame of mind, share the know-how by forwarding this newsletter to a friend or using the icons below to post it on social media. After all, a picture is worth a thousand words, but a clean photo feed is priceless.
