Compare docs the easy way
Compare docs the easy way: Collabing in Google Docs can get messy fast. Skip the side-by-side chaos of spotting changes manually. Instead, go to Tools > Compare documents and select the other file. Google creates a new doc with deletions crossed out and additions highlighted. Lifesaver.
