You buy a home security system to defend against thieves trying to break into your house, but there are more threats out there than just masked thieves outside your home.
Garages, sheds, other outside buildings and vehicles that are parked long-term can be just as much of a draw to thieves as your main house. Does your security system cover those? Probably not. What about a snooping guest, curious child or even someone working in your home, like a contractor, getting into places they shouldn’t? You won’t know until it’s too late.
Fortunately, the security system that’s protecting your home’s exterior can protect important things on the inside as well. It just takes a little creative thinking.
It all starts with sensors
A staple of any security system is the entry sensor. This uses two pieces — a sensor and a magnet — to tell if a window or door has been opened. Well, you can attach an entry sensor to a lot more than just a door or window.
To pull this off, it does help to have a security system that lets you set silent alerts for individual sensors. Instead of trigging a full-blown alarm, you’ll get a silent notification. It also helps if the sensors are wireless, so you aren’t running easy-to-see and easy-to-cut wires everywhere. For this, we recommend our sponsor, SimpliSafe. Read to the end to find out more.
Now, let’s jump into three ways you can monitor more than just the doors and windows into your home.
1. Medicine and liquor cabinets
Worried about a party guest, someone working in your home or even a grandchild snooping in your medicine cabinet or even stealing prescription drugs? Attach an entry sensor to your medicine cabinet door. You’ll get an alert as soon as someone opens it.
This is also a good idea for liquor cabinets if you have teens in the house. You can decide whether or not to tell them it’s there.
2. Safes and gun cabinets
Obviously, you want to know the minute someone opens your safe. An entry sensor inside the door can do that, and the snooper won’t even know it’s there. Yes, a good safe will keep out snoops and thieves, but it might be someone close to you who knows the combination — like a family member. It never hurts to know.
If you have a gun cabinet, it should always be locked when you aren’t around, period. However, if you have children in the house or even grandchildren that occasionally come to visit, an extra level of protection is never a bad thing.
Put the entry sensor on the gun cabinet door, so you know the second someone opens it. This is one you can set to trigger an alarm so that you can be there in seconds.
3. Outbuildings and parked vehicles
A detached shed, garage or another outbuilding is a tempting target for thieves, especially if they don’t want to test your home’s security. You’ll definitely want to throw some sensors on those.
If you have an RV or trailer in long-term parking on your land, thieves like to target those as well. Who knows what stuff you’ve left inside? Again, a wireless entry sensor is perfect for these situations. You don’t have to run wires all over the place, and they’re inexpensive and simple to install.
If you don’t have a security system, or your current system won’t do what I’ve just described, then we want to tell you about SimpliSafe.
If you have 30 minutes to spare, you can set it up yourself — no drills or holes necessary. Its inexpensive, no-contract monitoring saves you money while giving you full peace of mind that the pros are there if you ever need help. And you can control the whole thing from your smartphone or tablet.
SimpliSafe offers wireless entry sensors you can set up individually, so you have full control. The Secret Alerts setting is great. With this, you get private notifications sent to you by specific sensors you designate to be on an “alert-only” setting. These sensors won’t trigger a system alarm but send a discreet notification directly to you instead.
A single base station from SimpliSafe can have up to 100 devices programmed to it. That includes sensors, keypads and sirens. That’s enough space to outfit your entire property. Add sensors for motion, smoke, carbon monoxide, water and frozen pipes, and you’ve got everything you need.
Right now, you can get a free HD camera when you purchase a new system at Simplisafekim.com. Your system comes with a 60-day risk-free trial, so there’s nothing to lose. Try it out now and protect your home the easy, smart way.
