If you’re looking for a new computer to work on, you’re going to find yourself swimming in a sea of options. There are countless gadgets to choose from. Whether you want a tiny, simple laptop or a 2-in-1 that doubles as a tablet, you can find almost anything your heart desires.
That makes your shopping experience way more complicated than it needs to be, though. Instead of spending hours researching your perfect fit, here’s an easy way to find what you need. Tap or click here for a one-minute quiz that matches you to your ideal laptop.
All you have to do is answer a few questions, and we’ll point you towards the computer that best fits your needs. Aside from that, here’s another good starting point in your laptop journey. You can use the computers we use here at Komando HQ!
Here’s how our tech geniuses operate
Sure, you can go your own way. You can also follow in some experts’ footsteps. We have a few tech mavericks on our team who know modern computers inside and out. They’ve honed down on two gadgets they like more than any others.
If you’re looking for a new system to work on, here’s what our IT guys Jeremy and John recommend. We purchase computers from Dell, a sponsor of Kim’s national radio show and the brand we trust.
Best laptop: Inspiron 15
This powerful laptop has an 11th Generation Intel Core i5 processor and a 512GB solid-state hard drive. Enjoy crisp, colorful images on its 15-inch anti-glare LED-backlit display. You can also do a lot with its 16GB of memory.
This laptop is built for productivity, with a lid sensor that makes the machine power right up when you open it. This 5000 model is also equipped for ExpressCharge. In other words, you can charge up to 80% in just an hour.
RELATED: 4 warning signs your laptop is about to fail
Desktop of choice: Optiplex
This powerful computer is a good, solid machine that will hold up well for routine, day-to-day work. It will easily last you four to five years. Tap or click here to shop Dell’s Optiplex models.
We go for a model with an i5 processor, 16GB RAM and 512GB of storage space. That works well for most uses. If you have editors on staff or you process video or audio yourself, you may want to bump up the local storage.
Need help making the right choice for your business?
Sometimes it feels like the world is throwing everything it has at you. To succeed, you need someone to guide you through. That’s what Dell Technologies Advisors do. They have the tech advice to help you navigate whatever challenges you’re up against — and get you safely to where you want to be.
Dell’s experts will talk with you about your business, your needs and your budget to help you find the best option. It’s a free service, and you won’t be obligated to purchase anything.
Call an advisor at 877-ASK-DELL or go to Dell.com for free expert support.
Read more
Is your computer a mess? Your 5-step quick plan to clean it up
