Tag, you’re it
Tag, you’re it: Typing a long question for ChatGPT (or any bot)? Use XML tags to help the AI follow your thoughts. They look like this: <example>your words</example>. For phrases with multiple words, use an underscore <like_this>. This helps avoid those pesky hallucinations, if you have lots of info.
