AI is taking over
AI is taking over: You need to make sure your business can compete. Take a free test drive of Oracle’s AI tech right now, before it’s too late. I like learning from the best, and I bet you do, too!
Tags: AI (artificial intelligence), Best, business, drive, free, Learning, Now, Oracle, tech, test drive
ChatGPT prompts you’ll wish you knew sooner
ChatGPT has changed my life — and yours, even if you don’t use it as much as I do.
You’ve probably noticed the new AI search bar in all the Meta apps, including Facebook and Instagram. It won’t be long before all your most-used apps and services integrate chatbots. (Yes, I’m sure the folks at Google are quaking in their search boots.)
Continue reading
🦈 Fin-tastic app: Want to know where the sharks are? Researchers track sharks (not all) in this free app. Or use the map on their site.
Record your Mac screen: Maybe you’re sharing directions or want to show something to a friend. Hit Cmd + Shift + 5. A toolbar will pop up. Here’s a quick look at what each tool does. Pick your fave, hit Record, then press Stop when you’re done.
Hidden Windows features live in the Accessibility menu. We’re talking about the magnifier tool, text size settings, color contrast levels, voice-typing and narration features, caption settings, voice recognition and more. In Windows 10, go to Settings > Ease of Access. In Windows 11, go to Settings > Accessibility. So handy!
Did you know you can instantly silence incoming calls on your smartphone by simply pressing the side button — typically, volume up or volume down — once? Yup, it’s a tech secret the pros know.
Shopping sites don’t want me to tell you this: Prices change on some online retailer websites depending on where you live. Use the VPN I use, ExpressVPN, and switch servers until you find the lowest price. Buy through there, then ship it to your home address.
Goop, begone: Grab a ball of Blu-Tack and press it into your earbud speakers. Pull it away, and all the junk inside comes out with it. Gross, I know.
Boost your Mac: Widgets put reminders, appointments, birthdays, the weather, top headlines, notes and more right on your desktop. Scroll to the bottom of the Notification Center and click Edit Widgets. Click the add button in the corner of any widget, and drag it around to reorder.
Waiting game: The wired model of Google’s Nest Doorbell is glitchy. After lots of complaints, it’s finally getting a fix. No confirmation on when, but it’s still good to know, in case you were considering replacing yours.
So long, farewell: Anyone who upgraded to Windows 11 on an old PC that technically doesn’t meet the latest operating system requirements is out of luck. Folks are reporting their tech dinos are stuck in a reboot loop. If you’re in the market, our IT genius, John, recommends this solid PC for under $650 that’ll last for years. If you edit video or need more power, here’s his pick for well under $1,000.
