Too busy to read? Tap or click below to listen to the story on your commute to work.
(PssT! You can also subscribe to us on iTunes, listen on Spotify and hear us on Stitcher, Google Play and iHeartRadio, too. Tell a friend!)
Upgrade your home with these smart ideas
You’ve decided to upgrade your home to a smart home but, where do you start? Maybe some smart lightbulbs or a smart thermostat? Should you use an Amazon Alexa, Google Home or Apple Home Pod to connect your devices?
In this Komando on Demand podcast, Kim and her co host Andrew Babinski talk about the latest trends in smart home tech, and Andrew shares the trial and error he went through when he started “smartifying” his home.
They also talk about some pretty weird smart technologies like smart diapers, smart toothbrushes, coffee makers, and … Jim Beam? If you’re looking for some humorous yet insightful advice on how to start the smart home journey, don’t miss Kim and Andrew as they break it all down for you.
How to listen and subscribe on different devices
Don’t forget to subscribe to the podcasts so you never miss an episode. Here’s how to listen and subscribe on different devices:
For iPhone, iPad, or iPod Touch
Listening to the Komando FREE Podcasts on your Apple device is as easy as going to the podcast app.
- Open the Podcasts app on your iPhone, iPad or iPod touch.
- Click on the magnifying glass search icon at the bottom of the screen
- Select Search and type in “Kim Komando”
- Select the podcast from the list of search results.
- Click “subscribe” when “my podcasts” pop up
- Select the podcast you want to listen to and double-click to play
For Android gadgets
Follow these easy steps:
- Install the free Beyond Pod podcast player for your Android here
- Open the app and click on the MENU dots (those are the 3 dots in corner)
- Click “subscribe” next to Komando on Demand
- Add to a Category or click + New Category and Label the category “Kim Komando” Then select New Category
- Refresh the page
- Select what episode you want to listen to most and click play
