If you own one of the latest iPhone models, you probably shelled out around a grand for it. You’d think a gadget that costs that much would have a super-long battery life. But it doesn’t.
The iPhone XS Max battery lasts up to 13 hours for internet use, which is only an hour longer than the iPhone 7.
That’s why Apple has come out with a new smart battery case, to extend your iPhone’s battery life. But is it worth the huge price tag?
Does Apple’s smart battery case live up to the hype?
Apple started selling smart battery cases last week for some of its new iPhone models. There are cases for the iPhone XR, iPhone XS and iPhone XS Max.
According to Apple, the case will extend your talk time up to 37 hours, internet use up to 20 hours and video playback up to 25 hours. It also has a soft microfiber lining that helps protect your iPhone.
The idea of having a case that not only protects your gadget from being damaged if you drop it but extends its battery life sounds fantastic. But there are a couple of problems with Apple’s new case that might have you thinking twice before getting one.
The first thing that you’re not going to like is the bulkiness that the case adds to the phone. Here’s a picture of what it looks like:
(Image source: Apple)
Notice the big hump on the back of the phone. That can’t be comfortable to carry around in your pocket.
The next problem with the case is the price. It costs $129.
That’s a little steep wouldn’t you say? Especially if you’ve already dropped nearly $1,500 on the iPhone itself. There are less expensive options out there.
Alternative battery charging options for less
Instead of spending $129 for a smart battery case, check out these other options that will save you some dough.
Anker PowerCore portable charger
This portable charger has high-speed-charging technology. Anker’s PowerIQ and VoltageBoost combine to deliver the fastest possible charge for any device.
It’s also compact and portable. The device is smaller than a deck of cards and will easily fit into any bag.
You can buy one from Amazon for under $32.
Jackery portable charger
Here’s another portable charger that will work for your iPhone. Its built-in Lightning cable enables super-fast charging.
You can pick one up from Amazon for under $30.
5 port power bank
This universal power bank is an unrivaled combination of power and design that allows you to keep all your devices charged on the go. With 5 USB ports, it’s the perfect solution to charging on the go.
This unit’s tremendous power capacity of 10,400mAh charges up to 5 devices at the same time. Never run out of power again!
