Chrome 110 was released just last week, adding security upgrades that improve Google Password Manager while adding the ability to use biometrics to confirm your identity for auto-fills. Here’s everything you need to know.
The latest version of Chrome also aims to get more out of your battery and consume less memory. Here’s how it works.
Less of a memory hog
It’s simple: the more memory you use, the slower your device runs. Keeping dozens of tabs open at the same time is a prime example. Chrome knows its users (over 2 billion) and addressed this common practice.
With the latest update, Chrome now uses up to 40% and 10GB less memory. Memory Saver mode frees up memory from the tabs you aren’t currently using so that the ones you use run smoother.
Inactive tabs will reload when you get back to them, and you can mark off the sites you want exempt from Memory Saver. Look for the controls in the three stacked dots Chrome menu.
Chrome got a bump in speed some time ago, providing faster search results while using less memory. Chrome also began showing suggestions on what it thinks you might search for as you type in a query. Did you notice the changes?
RELATED: How to change the default browser and search engine on Windows
Your battery will thank you, too
Are you running Chrome on a laptop? The new Energy Saver mode kicks in when your battery drops to 20%. This limits background activity and visual effects for websites with animations and videos.
Update Chrome now
You’ll want to update your Chrome browser ASAP. Even if you don’t care much about the new features, security upgrades are important. Here’s how to update Chrome:
- Open the Chrome browser on your computer.
- Click on the three stacked dots in the upper right corner to access the menu.
- Hover over Help at the bottom and click on About Google Chrome.
- If an update is available, it will begin downloading automatically.
- When finished, click the Relaunch button to complete the process.
Chrome users, make this change now to limit ad tracking
How to clear your browser cache in Chrome, Firefox, Edge, Safari and Brave
