Technology advances so fast these days; if you don’t pay attention you’ll get left behind. And it’s not just those $1,000 smartphones that are breaking ground, either.
Automobiles, smartwatches, Internet of Things (IoT) and appliances are just a few things to keep your eye on.
Want help staying up on the latest tech? Tap or click here to sign up for our tech tips and how-tos newsletter and don’t miss a thing.
Gadgets that will help make life easier
There is one technological segment you really need to take advantage of. We’re talking about tech that will do housework for you. Here are some amazing products that will make life easier so you can sit back and relax:
1. Never hassle with dirty floors again
One of the most tedious chores around the house is vacuuming. I’ve always hated having to pull the vacuum cleaner out, untangle the cord, clean the floors and then reversing the process to put it all away. How annoying!
With this eufy BoostIQ RoboVac robot vacuum cleaner, you’ll never have to go through the hassle of vacuuming again. It vacuums for up to 100 minutes and works on both hardwood floors and carpeting.
2. Got pets? This will help keeps those stains away
If you have pets you know what a struggle it can be to clean up stains they leave behind. With this Bissell SpotBot Spot and Stain Cleaner, the struggle is over.
With just a push of a button, this machine delivers hands-free spot and stain removal on carpets and area rugs. This easy-to-use portable cleaner automatically sprays, brushes and suctions to remove both surface pet stains and tough, set-in stains
3. You don’t do windows? Me neither
“Cleaning windows is my favorite chore around the house” — said no one ever!
Get this Gladwell Gecko Robot Window Cleaner and you’ll never have to go through that pain again. Its smart AI design will clean your windows quickly and efficiently. No more climbing ladders and putting yourself at risk.
Instead, let the Gecko do the work for you. It uses an advanced algorithm to detect edges and scrub every part of your windows. You can even control it from the palm of your hand with its full-access app.
Want to become an Amazon Jedi? Tap or click here for 10 hidden tricks every Amazon shopper should know!
4. Who let chili explode all over the microwave?
I’m sure we’ve all been there. You set the microwave for a couple of minutes to reheat last night’s dinner and boom! It explodes in seconds, leaving a horrible mess to clean up.
The Angry Mama Microwave Cleaner is the solution to this annoying problem. This crafty cleaner uses steam to soften the crud from your microwave.
Just add vinegar and water, then microwave for 7 minutes. Easy peasy. Steam comes out of mama’s head and softens dirt and stains for easy cleaning. It’s practical and entertaining.
5. Grilling just got easier
Now that you don’t have to spend so much time cleaning up inside the house, you can spend more time enjoying the outdoors. That means it’s time to fire up the grill and whip up a feast for the whole family.
Even after an epic meal, you won’t have to worry about cleanup with the Grillbot Automatic Grill Cleaning Robot.
This motorized grill cleaner takes the elbow work out of cleaning for you so you can get rid of that old grill brush and scraper. Just place Grillbot on your grill, press a button and it does all the cleaning for you — no more scrubbing!
6. Save money by not having to hire pool cleaners
Keeping the pool clean can be expensive, especially if you’re paying pool cleaners to come over constantly to do it for you. With this Dolphin Nautilus CC Plus Automatic Robotic Pool Cleaner, you can save some bucks by keeping the pool clean yourself.
Set your Dolphin’s weekly schedule to automatically clean every day, every other day or every third day. Its powerful scrubbing brushes easily remove tough dirt and debris on the floor and walls of your pool in less than two hours.
7. Did anyone remember to feed Fido?
While you’re enjoying the great outdoors, it’s easy to forget the simple things like feeding the pets. Never worry about them missing a meal again with the PetSafe Healthy Pet Simply Feed Automatic Cat and Dog Feeder.
It lets you conveniently schedule up to twelve meals for your pets with flexible portions. Depending on your pet’s needs, you can set portion size anywhere from 1/8 cup to four cups.
The dispenser helps keep food fresh and prying paws out. The clear lid also lets you see when it’s time to refill.
The next few items still require a little work, but at least it’s easier …
8. Quickest and easiest way to clean the bathroom
Nobody wants to spend too much time cleaning the bathroom. This bathroom all-purpose power scrubber cleaning kit will help cut down on time and make it easier.
The kit comes with nylon power brushes that attach to your favorite cordless drill. The bristles will not scratch and can be used on tubs, sinks, baseboards, fiberglass shower enclosures, shower door tracks and porcelain.
9. Now, why didn’t I think of this?
Here is one of those ideas that seems so simple but also so useful you wonder why you didn’t come up with it first.
This Howard Window Blind Cleaner Duster Brush is just terrific.
It’s sturdy, durable and great for cleaning your windows, air conditioner or car blinds and works great with cleaning spray. It comes with five microfiber cloths that pick up dust quickly and easily.
10. Look your best and be ready for all your important meetings
Ever have an important meeting or job interview only to realize your best suit is covered in lint or fuzz? Use this Conair Fabric Defuzzer and you’ll be all cleaned up in no time.
It has a detachable lint catcher, a comfortable grip and is easy to use. You can adjust the settings depending on the fabric type for customized cleaning.
11. Cleaning so easy it’s like magic
These MagicFiber Microfiber cleaning cloths are a must-have for every home. They are ideal for cleaning oil and dirt off any delicate surface like TV screens, smartphones, tablets, camera lenses and filters, and much more.
This set comes with three oversized microfiber cloths that are perfect for cleaning all of those larger surfaces, screens and devices. Use them to help keep all of your gadgets clean and like new.
