© Gpointstudio | Dreamstime.com
3 simple tech resolutions you can actually keep
If you have ever made a New Year’s Resolution, you know how difficult it can be to keep. But just because 2021 has been just as much of a mess as the year before, it doesn’t mean that you shouldn’t use tech to go into the new year.
One way to be more productive and make life easier is by adding apps to your mobile devices. You can find apps that do pretty much anything you can think of, from entertainment to work and so much more. Tap or click here for the best home inventory apps to help sort out all your stuff. How’s that for a resolution?
Another way to start 2022 the right way is by getting all your devices in order. It’s time for a technological makeover, and here are three tech resolutions that you can actually keep.
Wipe your old devices
Christmas is a popular time for receiving new gadgets and electronics, and who doesn’t want to ring in the new year with brand-new technology? But before you go all in with your new device, you should plan what you will do with your old ones.
The best starting point is to sign yourself out of any profiles or services on the old device. Remove or transfer any photos to cloud storage, or make sure that you have backups.
To wipe mobile phones and other portable tech devices, it’s usually easy to reset them to their factory settings. By doing this, all personal information and data will be deleted from it, making the device safe for yourself and others.
For computer hard drives, a simple format should be enough but look at open-source software to do a professional deep clean on the drive. Tap or click here for step-by-step directions to wipe a hard drive on your Windows PC or Mac.
Once you are confident that the device has been wiped, you should consider donating it or sending it to a recycling facility.
The Environmental Protection Agency (EPA) has a handy list of where you can donate your electronics. You’ll find technology companies that will dispose of devices on your behalf or recycling facilities in your state or community.
Update all your tech
Earth gets a clean slate around the sun, so why not do the same for your technology? Ring in the new year by updating operating systems, drivers or software versions for all your devices.
Having the latest drivers and software versions installed will make sure that you get the latest features and updates — as well as patch potential security issues. And while you are at it, why not set up your devices to update automatically?
RELATED: Ransomware: Yes, you’re vulnerable to this, too. Here’s how to stay safe
For Windows PCs:
  • Open Settings and click Update & Security
  • Click Check for Updates
  • If any updates are available, Windows will automatically start downloading them
For Mac:
  • Click on the Apple icon in the top left-hand corner of your screen
  • Click on System Preferences
  • If there is an update available, a notification icon will be displayed over the System Preferences icon
  • Click on Software Update
  • If there is an update available, click on Upgrade Now
To make things easier in the future, check the box so that your Mac automatically keeps your system updated.
For iOS devices:
  • Open Settings and tap General
  • Tap Software Update
  • If there is an update available, tap Download and Install Now
  • To set up automatic downloads, tap Automatic Updates and slide the toggle next to Download iOS Updates and Install iOS Updates to on
To update your apps on iOS:
  • Open the App Store
  • Tap on your photo in the top right-hand corner
  • If there are any app updates available, tap Update All
To check for updates on your Android phone:
  • Tap Settings
  • Tap About Phone and then tap Check for Updates
  • If an update is available, tap Update
Adjust your notifications
It’s been a crazy year, so why not go into 2022 with fewer distractions? There is really no need for email to be buzzing and displayed on your computer, mobile phone and smartwatch. Turn off notifications for at least two of those devices or set them to silent.
Do the same for Facebook Groups if you are a member of several pages. Snooze some of the notifications for 30 days or choose not to be alerted when a post has been made. You will still see when there is something new, but you won’t get an intrusive alert.
RELATED: Quick and easy way to stop phone notifications for good
Take some time out of your day to review all the notification options on your iOS device. By tapping Settings > Notifications, you can adjust how individual apps notify you and display alerts. And don’t forget — iOS 15 rolled out earlier this year with new Focus features to block distractions. Tap or click here to see how it works.
For Android phones, you can change notification settings by tapping Settings > Apps & notifications > Notifications.
Bonus: Use a VPN
Start the year safe and secure by using a Virtual Private Network (VPN). A VPN encrypts your entire internet connection to protect all your communications, even over unsecured networks. It stops your internet provider from tracking you — something your browser’s incognito mode can’t do — and lets you unblock websites and bypass filters.
We recommend our sponsor, ExpressVPN. It’s super easy to set up on smartphones, tablets or home computers.
Protect yourself with the VPN that Kim uses and trusts. Visit ExpressVPN.com/Kim today and get an extra three months free on a one-year package. You can’t beat that!
