© S Walker | Dreamstime.com
Simple way to save money on printing costs
Presented by Epson EcoTank
See why Epson EcoTank printers are Kim's printer of choice at Epson.com/EcoTankKim.
https://epson.com/ecotank-ink-tank-printers?utm_sourceutm_mediumothutm_termutm_contentutm_campaignus-kimkomando+general+hyperlink
Now that many of you are working from home due to the coronavirus, you’re probably printing more documents than ever. That could cost you a fortune in ink cartridges. But, it doesn’t have to.
Make the switch to an Epson EcoTank printer and you’ll save tons of money on printing costs. See why the Epson EcoTank printers are Kim’s printer of choice at Epson.com/EcoTankKim.
Right now, there are two basic types of printers for the regular consumer: the laser printer and the inkjet printer. But did you know there’s a newer, revolutionary way of printing that could save you a significant amount of cash in the long run? Kiss expensive ink cartridges goodbye!
Laser printers
Laser printers use technology similar to photocopiers. A rotating drum creates the image with static electricity that attracts the toner. This toner is then quickly baked into the page using hot fusers.
For black text on plain paper, laser printers are a good choice. They print faster than inkjet printers and they render small, fine text better. Although the initial cost of laser printers is a bit higher than comparable inkjet printers, toner replacements are cheaper than inkjet cartridges.
If you print tons of mostly monochrome text, then a monochrome laser printer is the way to go.
Inkjet printers
Inkjet printers draw pages by forcing liquid ink through microscopic nozzles. For all-around, multi-use color printing, inkjet printers are the way to go since they render photos better than laser printers.
Consumer inkjet printer units are also cheaper than laser printers, and they usually come with starter cartridges to get you printing right away. The downside is replacement inkjet cartridges are more expensive than their laser toner counterparts, so operating costs may add up more in time. Inkjet printers are also slower than laser printers.
For home multi-purpose printing, be it text, photos or labels, inkjet printers are the better choice.
EcoTank Printers
Now, how about an inkjet printer that will let you refill its high capacity tank yourself, saying goodbye to those expensive ink cartridge replacements?
Epson’s new line of revolutionary EcoTank SuperTank printers will let you do exactly that!
With yields of up to 11,000 black-and-white pages or 8,500 in color out of the box, Epson’s EcoTank printers forego the use of traditional inkjet cartridges by using their own user-refillable high-capacity tanks.
Compared to the mere 500 black and 450 color pages you get from even the high capacity inkjet cartridges, this is an extremely significant improvement.
Replacement EcoTank ink sets are much, much cheaper, too. A complete EcoTank set will cost about $58, with yields of up to 6,500 pages. A complete color inkjet set for a comparable non-EcoTank printer will cost about $150, and that will only yield up to 2,300 pages.
That’s a whopping 80% savings compared to traditional inkjet cartridges.
The initial cost of the Epson’s EcoTank line of printers may be a bit steeper than conventional inkjet printers, but they more than makeup for it in the long-run. Epson estimates that with the initial ink that comes with EcoTank printers, the average user won’t need replacement ink for two years!
For more details about these revolutionary printers, check out Epson’s EcoTank page. Kiss expensive ink cartridges goodbye! See why the Epson EcoTank printers are Kim’s printer of choice at Epson.com/EcoTankKim.
