When you’re browsing the web, it’s easy to fall down fascinating rabbit holes. Sometimes, you come across a webpage that you want to save to your computer. Sure, you could copy the text or even take screenshots.
Tap or click here to get the best screenshot tool for your computer. But taking screenshots of an excellent webpage can be a long and complicated project. Instead, you can get the job done quickly by exporting a website as a PDF on your Mac or Windows computer.
Of course, you might worry about all those ugly ads cluttering the file. Luckily, we know how to get rid of those ads so you can focus on the content that drew you in. We even have specific instructions for Mac or Windows users.
How to save a webpage on Safari
If you want to save the webpage precisely as it is, follow these steps:
- First, open up Safari.
- Go to the menu bar to select File.
- Scroll down and select Export as PDF.
- You’ll see a new popup window where you can rename the file and choose the save location.
- Hit Save.
Next, let’s go over how to clean up the webpage before saving the file.
How to save a webpage without ads on Safari
This is a great trick, especially if you plan to print the PDF later. Or, if not, this creates a clean, simple copy that is easy to read. You won’t have to be distracted by weird ads for toe fungus cream or whatever else the web throws your way.
- Next, click on View.
- Tap Show Reader.
- From there, go to File.
- Select Export as PDF.
- Hit Save.
Now you’re good to go. By saving through the Reader View, you ensure your PDF is easier to read later. When you open the PDF, it will look like a series of pages. Overall, it gives your document a professional look. Plus, it’s a breeze to navigate.
How to save a webpage Google Chrome
This is pretty simple.
To get started, just hit the three dots at the top right corner of your screen. (It’s to the right of your icon.) From there, hit Print. This will open up a print preview of the page you’re interested in.
To the right of Destination, you’ll see an option that says Microsoft Print to PDF. Click the drop-down arrow to the right and select Save as PDF. Then, hit Save.
Now you have an ad-free PDF saved to your computer. Even if your internet gives out, you can return to this file for your future reading pleasure.
Saving files for later access is a great trick. But are you backing up those files?
Sure, you could back your files up in the cloud. But depending on the company providing the cloud, it might not be a safe storage spot. Kim recommends her sponsor, IDrive.
Every once in a while, the computer you rely on can fail you. No, it’s not the hardware or the software — it’s malicious viruses or even ransomware that takes over your system. Imagine a hacker gaining access to your computer and denying you access to your data until you pay a hefty fee. Don’t leave your computer unprotected. Defend your data with IDrive.
Save a whopping 90% when you sign up at IDrive.com and use the promo code “Kim” at checkout.
