Raycon
How to find earbuds that fit your ears
Presented by Raycon
Presented by Raycon
Get 15% off your order at BuyRaycon.com/Kim.
Streaming music players, Bluetooth-connected TVs and your smartphone. Those are just a few of the devices you can go hands-free with if you have wireless earbuds. Hands-free technology is more than just a convenience. With the right pair, you can also drive more safely with hands-free calls.
The problem for most of us is finding quality earbuds at a price that doesn’t break the bank. Until now! Raycon earbuds start at about half the price of other premium wireless earbuds on the market — and they sound just as amazing as those other brands. Not only that but they are super comfortable to wear.
If you’re stuck of earbuds that fall out, hurt your ears or just aren’t comfortable, it’s time to treat yourself to an upgrade. You save even with 15% off your order at BuyRaycon.com/Kim. Use code KIM.
Earbuds that actually fit
One major problem you’ll typically find with inexpensive earbuds is they don’t fit properly. You’re lucky if those cheap options come with two different sizes: way too big and way too small. Or maybe they’re one-size-fits-all, which we all know is code for “Good luck getting a nice fit.”
Not having the right size earbuds results in multiple problems. First, they aren’t going to be comfortable at all. Imagine having an earbud that’s clearly too big jammed into your ear for any length of time. No thank you!
Another issue is the material used to make them. Many times earbuds are made from hard plastic, which adds to the level of discomfort.
If the earbuds are too small you’re going to struggle to keep them from falling out of your ears.
This leads to another problem: They won’t sound great. If your earbuds don’t have the perfect fit, it impacts sound quality. You need the right sized earbuds to get that premium sound we’re all looking for. Choosing between comfort and sound quality isn’t something you should have to deal with.
You won’t have these issues with Raycon earbuds. These bad boys actually come with six different sized soft-comfort gel tips. They range in size from extra small to extra large.
And don’t throw the extra gel tips away because you may need them later. Did you know that as you age your ears get bigger? It’s true, which is one reason having spare gel tips of different sizes is the perfect solution to this age-old problem.
Which version is right for you?
When you’re deciding on the best earbuds at reasonable prices, Raycon has a couple of different options for you to choose from. Let’s begin with its most popular model.
Raycon’s Everyday E25
Raycon’s Everyday E25 Earbuds are everything you need and more in wireless earbuds. They’re made from high-performance drivers with a powerful built-in battery that lasts up to 24 hours.
Features you’ll love:
  • True wireless technology
  • Secure in-ear fit
  • Six custom gel tips
  • IPX 4 water-resistant
  • Powerful bass
  • Noise isolation
  • Six hours of audio playback time
  • 24-hour battery life
  • Small and lightweight
  • Compact charging case
If you want an upgraded experience, Raycon has another option just for you.
The Performer E55 wireless earbuds
Raycon’s Performer E55 earbuds are based on real customer feedback to deliver expertly balanced high-fidelity sound. Bass-boosted audio cores meets the latest chipset to keep you tuned in to your favorite music and podcasts throughout your day.
The curvature of The Performer E55 is designed from the ears of actual people for the best fit possible. Paired with customizable soft-comfort gel tips, you’ll forget you’re even wearing earbuds.
The E55 earbuds offer up to 36 hours of battery life with the wireless charging case. These earbuds will last overnight, and then some. The case is fully compatible with a Qi-compatible charging mat so you can charge on-the-go. (Note: charging pad sold separately.)
You’ve heard Kim talk about how the company was co-founded by Ray J, and celebrities like Snoop Dogg, Cardi B and Melissa Etheridge are obsessed with Raycon. Now’s the time to see what the hype is all about.
Try them for yourself, and get 15% off your order at BuyRaycon.com/Kim.
