dash cams for your car under 100 dollars
Kim recommends: Dash cams and dash cam apps
On the July 13, 2019, episode of The Kim Komando Show, a caller asked about dash cam technology to install on his vehicles to help with some family issues.
Kim recommended that you can find dash cams for over $100, but you don’t need to spend that much. She also recommended to the caller that he and his wife try dash cam apps for their smartphones or smart devices.
Dash cams you can install yourself in your car
Dash cam apps for iPhone and Android
Apple
Nexar AI Dashcam
Smart Dash Cam fro IPCamSoft
Android
AutoBoy dash cam for Android from Google Play
Smart Dash Cam from IPCamSoft
As an Amazon Association, Komando.com may earn a commission from qualifying purchases made on Amazon.com.
cryptocurrency e-book hero
Check it out
